What year?
daman
What year?
Post by daman »
Was considered the better years with less problems? im thinking '85 and up??
were they all the same HP?
An 83 with the updated Red dot oil pump and jetting is all good. The only big performance wise change came with the 87 and the upgraded ignition.
daman
Post by daman »
K but 85 and after had all that updated jetting issues and oil pump from factory???
daman wrote:K but 85 and after had all that updated jetting issues and oil pump from factory???
= Yes !
the 84 also had the correct oil pump but im not positive what main jets came stock either way dont let that discourage you from buying an 84 either
daman
Post by daman »
Alright,,so are these the only issues then with these sleds(minor at that)????
i had one back in the day should have keep it.
daman wrote:Alright,,so are these the only issues then with these sleds(minor at that)????
Lots of reading in the Articles section or if you do a search. C.D.I.'s sometimes fail and as far as reliability it is All in setup.....
daman
Post by daman »
yup been reading,thanks for the info appreciate it.
stators seem to burnup more than they should too.. but how much can we really expect from 22+ year old windings?.... either way there isnt a year that has any major issues.. rotating assembly all stayed exactly the same from 83-87 (and longer if you figure in the canadian models)
It really doesn't matter ,they All are very reliable sleds if you just do normal maintenance on them. It's more of a matter of which one you like the best.
