please help 86 vmax wont stay running
minocqa
Post by minocqa »
hi
Please help
i was getting my vmax ready for the season and it wouldn't start so i siphoned out the old gas changed plugs and i poured a little gas down each cylinder and pulled it over a few times,so then i added new gas installed plugs, pulled it started on first pull then as soon as gas burned out of the cylinders it died and wouldn't restart without pulling the plugs and pouring a little gas down each cylinder , it started right up then died. ...any help would be greatly appreciated i admittedly don't know much about snowmobiles please help
thanks
Re: please help 86 vmax wont stay running
Make sure the fuel shut offs are turned back on
check your fuel shut off if thats not it youur fuel pump took a dump .
minocqa
Post by minocqa »
hi
could you tell me where the fuel shut offs are located ?
thank you
minocqa wrote:hi
thank you
1983-85 Behind the radiator under the hood
86-91 Lever on the dash (fuel shut off "ON Position" means fuel is shut off) lesson I learned years ago.......
http://www.vintagevmax.com/serial_numbers.htm
minocqa
Post by minocqa »
thank you so much for your help it runs :D
Post by chrisrider63 »
Some idiot took the shut off vvalves off my vmax these shoemaker hacker mechanics kill me.
if the fuel is on, then your carbs are dirty. take them off and clean them
