83 VMX 540 sold thanks
MELROSEMAFIA
Re: 83 VMX 540 MAG SIDE TEMP ???
What are you using to gauge cyl temp, EGT or head temp?
MELROSEMAFIA
Well then, I assume you are either doing this at an idle, or you can run very fast.
At idle it could or probubly is idling on one cyl more then the other. Could be a idle screw setting, not enough slack in one side of the cable, ajustment of the low speed screw, plugged low jet, bad plug or wire on that side. The next question would be, do the temps even out as the sled is run at speed?
