1981 yamaha srx
hippi
1981 yamaha srx
Post by hippi »
Im looking for a coil for my 81 srx, stock coil part # is 8m6 82310t000
do I get anything with a 82310 number in even if the first three numbers and leters are different or what do I use what sled will match up to a 81 srx
also in a comit 102 clutch witch spring color do I use also what ramps do use
also decales for this sled whare can I find some
If I use a set of 38mm round slides what main jet size should I use
I was thinking 400 for mains is that a good place to start for jetting
Bryan
welcome to vintagevmax... if you read around the site i think you learn more than you ever imagined, including the answers to your questions but here you go, correct me if im wrong guys...
the coil from any 81-91 srx/vmax should work but the vmax ones mount slightly different...
i think the spring for a 102 on a srx is the square yellow one you have to engage it very high like in 4600+...
jon bertolli has stickers i believe...
400's sound really fat ive always heard to start with the vmax specs but have never successfully done it.. .the mains in a vmax are depending on the year and altitude 290-310...
Welcome to Vintagevmax ! Check out the sticky post at the top of forum and call Gary W. for decals !
http://www.vintagevmax.com/vvforum/viewtopic.php?t=445
hippi
thanks
Post by hippi »
thanks for the help
I will be doing posts every fuew days or weekly when I find more things wrong with this sled I will have some photos by the weekend just picked up last weekend it only had 1333 miles so she is in nice shape just some dumb ass that tore things off before I bought it along with a blown motor witch fixed already
this is my first yamaha so gental with me
have alot of cats ,rupps ,mercs, ski doos about 22 of them to be exact
thanks again for the help
Bryan
hippi
81 srx
Post by hippi »
here are shotz from day one the blue and yellow are now gone first thing I did was get rid of those colors I like the black look and I will add decales all my pictures did not show up I need to call on them tomarow when I get the rest I will post the new look
bryan
hippi
81 srx
Post by hippi »
got spark
need my clutch and carbs to move on
"the blue and yellow are now gone"............ and to think someone thought that was the cats meow ! :shock: Keep up the good work !
hippi
81 srx
Post by hippi »
black is back
hippi
done
Post by hippi »
well shez done Ill get picks up when decals show up and I get them on .
up and running sounds good still need decals will have in two weeks now I need snow to try it ,first show will be august 23 in Greenville ,Mi. at snow motion for the BEVRA show /drags stop on out good show and drags
hippi
out
woodydog
Post by woodydog »
Just to let you know, the side panels should be painted with a semi flat black. Not glossy, just wanted to let you know before you put your decals on.
mjd
hippi
too late
Post by hippi »
thanks for the info ,to late to change
well itz not to specs ,itz close for me itz better that what it did look like yellow,blue and green UGLY thanks anyways
hippi
hippi
latest and greatest
Post by hippi »
new shotz from BEVRA show also my merc and 6000
davet
Post by davet »
Looks Great !
im in the process of re-assembly on my 81 right now.
