Donnie
Posts: 65 Joined: Fri Jan 27, 2006 11:04 pm
Post
by Donnie » Fri Dec 28, 2007 1:48 am
Hey all,
Can I swap my '83 stator with the newer one that has the extra wire for hand warmers without any other changes?
Donnie
Donald L. Gilbert, Jr.
1983 Yamaha Vmax
1986 Yamaha Vmax
Posts: 214 Joined: Mon Dec 18, 2006 9:50 pm
Post
by opsled » Fri Dec 28, 2007 1:42 pm
Yup.
jipcee
Posts: 99 Joined: Sat Nov 17, 2007 1:36 am
Post
by jipcee » Fri Dec 28, 2007 9:07 pm
Yes. But i'm not sure if the extra lead will have power with your flywheel.
I have a 85 stator in my 83 and I get no power to the wire. It could be bad. But everything else works as usual.
Hey, opsled HOW MUCH SNOW DID YOU GET TODAY (Friday Dec. 28)?
Post
by opsled » Fri Dec 28, 2007 9:49 pm
We probably got about 8" or so and it is stiil coming down although not as hard. It is the wet heavy stuff though an very slippery.
Donnie
Post
by Donnie » Fri Dec 28, 2007 11:42 pm
I have an 85 flywheel and it looks the same. Does anyone know if the handwarmer wire will work then?
Donnie
1983 Yamaha Vmax
1986 Yamaha Vmax
jipcee
Post
by jipcee » Sun Dec 30, 2007 2:22 am
Donnie wrote: I have an 85 flywheel and it looks the same. Does anyone know if the handwarmer wire will work then?
Donnie
I might have a problem with mine. If the flywheel looks identical it should work.
OPSLED: Had to west of Rockford today. They got 6+ out there.
Hope you had a good ride!
..................................................jipcee
Posts: 299 Joined: Tue Jan 31, 2006 12:34 am
Post
by vmax-540 » Mon Dec 31, 2007 12:22 am
You should use the newer flywheel as well , I was told by a Yamaha Technician that the magnets were different to power the extra coil . If you put both the stator and flywheel on then the extra wire will work, just feed it up to the hand warmers and you are good to go..
