speedo???
notorious1_Travis
speedo???
Have you guys had problems with the speedo cable on the 86 540?Mine just died lastnight.i like to keep track of the miles i put on a year.1126 as of now!!let it snow!!thanks guys.
yeah i dont think it is reoccuring problem but i managed to break a cable once... i think a lot of these old yamaha's used the same set up... its really just a tight coil with a square drive on both ends... mine broke near the footrest where it makes the turn... i sprayed lithium lube in the new one and straightened the curve as much as possible, its been running fine since.....
I threw a belt once and it kinked the cable.
The inner part broke soon thereafter.
I replaced the entire assembly with one that did not have holes in the jacket from the belt strings whipping the plastic off.
I tucked it a little further down in the footwell to protect it better.
I have not had any problems since.
