carburator installation
Marc Machine
Post by Marc Machine »
I read a while back in this forum section about a couple of guys criss crossing their carbs when re-installing. Ive asked guys I know that have snowmobiled for years if there is such thing as a left and right carb, they claim no, a 38mm carb is a 38mm carb.
But I agree with the VVM guys, my carbs do indicate a left and a right carb, why would it make a difference?
ZRXwannabe
Post by ZRXwannabe »
Some times the carbs are jetted slightly differant from one side to the other. This may be one reason. Although I don't think the Vmax is. It's more common on triples.
2008 Concours
2000ZRX
1983Vmax
Joe
Post by Joe »
The power jet and power air jet sizes are one size different. Otherwise they are the same.
Where are the carbs marked? I have never seen any markings on my carbs.
Carburetor- Mfr.- Type/ Size/ Qty/ ID Number Mikuni- VM38/ 38mm/ 2/ L:80N-00 R:80N-00
Main Jet/ Main Air Jet 290/ 2.5
Slow Jet/ Slow Air Jet/ Air Screw Ø/ Ø/ Ø
Pilot Jet/ Pilot Screw (Turns Out) 40/ ½
Needle Jet/ Jet Needle- Clip Position/ Cut Away/ Air Jet Q-0/ 6DH1-4/ 3.0/ Ø
Power Jet/ Power Air Jet L:135 R:130/ L:1.5 R:1.4
Fuel Inlet Valve/ Float Level 1.5/ 18.1mm
yeah the carbs are marked... its right by the choke... .i dont believe there is any difference in the casting its all in the jets
