I have just purchased an 1987 Vmax that the guy said he replaced the seal on the bottom. But I noticed a small amount of fresh oil under the oil tank & motor area. I wiped it up and it seems to be there again. Can anyone think of what it might be? The sled starts really good on first or second pull all the time. What should I look for or be looking for. I have checked all the clips in case they were off or loose.
1987 Vmax Oil Leak
91 Vmax sled
1987 Vmax Oil Leak
Keep on Sledding, Mild to Wild
i had this problem.... the clamps didnt seem loose but when i changed the ones on the oil pump the leak quit.... you can try to put a peice of paper towl in your belly pan and then keep an eye on it it should show you where the oil slick is originaling from
91 Vmax sled
