What is everyone doing with the oil injection systems? I have a 83 and no faith in the system. Right now I mix gas and run the injection but i am planning on not using the injection. Would it be good to just disconnect the cable and let it run on "idle mode" all of the time, or do people completely remove the injection
Dennis
Oil injection
I've never had or seen an issue with them but others say they have. I've seen Vmax 540's, Exciter's, Vmax 5 and 600's, Vmax4's, etc with many thousands of miles on them that have never had an issue with an oil injection related problem. I'm sure there have been failures but I don't think it's common or something to be really concerned with. On a trail sled I would leave it hooked up and adjusted. Some move the lines to the manifold as they think it is a safer way to inject the oil. Others will completely remove it and premix. You could run it as is, run it and premix or remove it, the choice is yours and I don't think you will get 100% agreement on the issue anywhere. Personally I think the sceptics on Yamaha's oil injection method of injecting oil into the fuel line before the fuel pump is over hyped but I'm not being paid for a professional opinion on the matter or trying to sell someone a kit to fix it so what do I know.
Undertaker#13
injection vs no..
Over the years I 've developed a trust in Yammie's factory oil injection pumping-routing systems. Mainly because the sys. faithfully served so many original engine configurations, over so many models and years. If you are now looking at any changes to carb airflow, porting, overbore , or custom pipes whatever, then it's best to premix racing type oil with higher octane gas. Ahh, good luck to ya. MJD
Undertaker#13
