If I go to a larger mm carb (long story) would I revert back to the original size jetting from original carb, or is there a conversion that needs to be calculated?
ex: if it ran good with 210 mains in a 38mm carb, and for whatever reasom I was going to 40mm carbs, would I still use 210 mains? etc...
you can email me: cptnjack@charter.net
silly ?
Hmmmmm.......Good question.......... the larger carbs would flow more air and with the same size jets this would be leaner, right ?
