Charge coil,Crank seal ????
Post by jefflanthier »
Has anyone experienced difficulties with the charge coils or crank seals in there 85 VMAX. My sled starts and runs like a top until it warms up and then runs like crap sounds like on 1 cylinder smokes quite abit. The carbs fuel pump and compression are all good and i already tried a new coil? dealer doesnt think its the charge coil either because it runs..The choke cables arent hanging up either, Any advice would be appreciated. This is an awesome old sled i might add one of the better sleds in its day. Jeff
Guest
Post by Guest »
Jeff, Check your coil ohm resistance against the specifications in 1986 service from the articles !
Electrical- Mfr./ Type Hatachi/ CDI
Headlight/ Taillight/ Meter light Ratings 12v 60-55w/ 12v 23-8w/ 12v 3.4w
Lighting Coil Color Code/ Resistance/ Output Yellow~ Black/ 0.25 Ohms± 10%/ NA
Handlebar Heater Coil Color Code/ Resistance Yellow-Black~ Blk/ 0.77 Ohm± 10%
Ignition Coil Resistance Primary/ Secondary 0.12 Ohm ± 10%/ 4.0 Kohm ± 20%
Source Coil Color Code/ Resistance Brn~Red/ 25 Ohm ±10% White- Red~ Red/ 10 Ohm ± 10%
Pulsar Coil Color Code/ Resistance White- Green~ Black/ 100 Ohm ±10%
Spark Plug Type/ Gap/ Torque NGK BR 9EV/ 0.7~0.8mm/ 2.75 m/Kg (19.9 ft/lbs)
Ignition Timing 1.6mm BTDC
Also check the Throttle override switches as that was the problem they had with the 85s .There was an update in 86 your sled may still have the old switches. I would bypass the switches and try that and see what happens.
