guys, i need a picture, got ahead of myself.
OIL INJECTION RESVIOUR LINES TO OIL INJECTION Pump. NEED TO KNOW WHAT LINE GOES WHERE ON PUMP. lmfao. going in circles here. 3:16
Re: guys, i need a picture, got ahead of myself.
Don't have a picture Tony but it isn't hard to explain.
Two tank ports on the pump.
The port directly below and closest to the bleeder screw is supply. It is also the port closest to the rear of the sled when engine is mounted.
The other port is return to the tank.
Supply line to the pump is the one with the filter in it. As I recall the piece of line between the filter and tank is larger than the rest and should only have one possibility for hookup on the tank. If not it should be the tank port that is closest to the right side of the sled when the tank is mounted.
Rule of thumb on all these types of Yammie pumps is supply port is closest to bleed port.
