Carb Tuning Question
maxvmax
Post by maxvmax »
How many turns out should the idle screw be? I am having a problem with a real high idle. I have the screws 3 1/2 turns out and it idles at 2,000 rpm.
I am thinking I have a slide/s facing the wrong way. Should the cutout portion be facing the airbox?
Chris
yo
Post by chrisrider63 »
Is there tension on your throttle cables somewhere/somehow?? Is it running lean?? Check the plugs..I kinda liked mine running at a higher idle it wont bogg that way with the stock spring.
"Should the cutout portion be facing the airbox?" Yes !
Are the carbs in sync ? Are the slides comming down the whole way and resting on idle screws ? Do you have an air leak at a carb mount or engine seal ?
maxvmax
Post by maxvmax »
I should note that it runs really well otherwise.
I will pull the plugs and check along with checking all the rubber boots on the carbs.
Is 3 1/2 turns out on the idle screw excessive?
Chris
