SECONDARY SETTING. 3:16
YAMMIEGOD 3:16
WHAT ARE YOU GUYS RUNNING ? I AM AT C-2. 3:16 (yammie tony)
Re: SECONDARY SETTING. 3:16
i have mine twisted as tight as i can get it, for circle track racing.... it pulls a major holeshot on the 600's
Tony.. B-2 is the best starting point, that is 60 degrees most Stock sleds seem to work best around this setting. I think you will find somewhere between 60 - 80 degrees will work best for your sled. For some reason I think I used C-3 when I had the ported cylinders on mine. Getting old and harder to remember!! lol
YAMMIEGOD 3:16
CRAZY JEFF. 1983 TECH MANUAL I HAVE SAYS B-2 @ 60 DEGREE WITH 8M6 BELT. THAN ITS SAYS STOCK SETTING (c-2) FOR LOW SNOW/ COLD ICE CONDITIONS. I AM GONNA TEST AND SEE. B-2 IS WHERE ITS GOING IF RPM IS LOW. 3:16 (yammie tony)
Tony You are right there is a lot of confusion on ALL the 83 Vmax specs, sounds like Yamaha tested right up to the last minute.
YAMMIEGOD 3:16
also had several different jetting spec,s too. 3:16 (YAMMIE TONY)
That's what I mean just about everything is different..
Tony are u setting it for drag or top speed I set my 81 at c2 with your helix in it and a gained 5mph over stock setting I ran this back to back in 1000 feet who cut this helix for you? It works talk soon kenny
YAMMIEGOD 3:16
kenny i don,t remember LOL. IT WS ONE OF THREE PLACES. AAEN, PSI, OR I HAD IT DONE AT WORK. TOLD YA THAT WAS A GOOD HELIX. 3:16 (YAMMIE TONY)
Tony that helix cost me more than two grand to get it when u get a chance can u post the rpm spec for the 82 srx
YAMMIEGOD 3:16
I WOULD OF GIV,IN YA THAT HELIX, I THINK YOU SPENT $2035.00 rotflmao . BUT THATS ME !!! i will get ya that 82 info. 3:16 (yammie tony)
