SRX 440 project
SRX 440 project
Ok i came across one of the vintagesled forums today from last january that talked about the update SRX 440 stator and Ignition system. How do i know if i have this stator plate that was the old and better one? What other componnents do i check to have the fast SRX 81 setup?? Also justin from the site informed me that the bottom end from the 81,81 SRX is the same as the v-max bottom end. (volume and composition) Also where do i get pistons for the SRX 440 81.
Re: SRX 440 project
If you have the old CDI unit it will say TIA01-33/Hitachi I dont know if it also says #8K4 the older unit has a 3 pronger connector the magneto Flywheel says F170-57chrisrider63 wrote:Ok i came across one of the vintagesled forums today from last january that talked about the update SRX 440 stator and Ignition system. How do i know if i have this stator plate that was the old and better one? What other componnents do i check to have the fast SRX 81 setup?? Also justin from the site informed me that the bottom end from the 81,81 SRX is the same as the v-max bottom end. (volume and composition) Also where do i get pistons for the SRX 440 81.
The stator #TRIZ 24B Hitachi
Uppdated (Same as SRX 500) Unit Magneto Flywheel # F170-58 (Four Plunger Connector) CDI Unit TIA01-38 #8R9 Four plunger connector. Stator #TRIZ 50 Hitachi
Or S85116B Toshiba. There were an Kit in the Improvement Service Bullentin for the 440 With the new 4 Pronger Connected CDI Unit to fit the 3 Pronger connection Magneto flywheel That also required to install some new electrical wires.
The Crankcases are different in both ends the Vmax case are a little Longer than the 440 Case because of the Bigger Bearings that the Vmax Crank Carries. Vmax Cranck will not fit in the SRX 440 crankcase But some say that you can use the SRX 440 Cyls and pistons on the Vmax motor if that was your intend. But i don't know if you will make the same horsepower anymore then. Because the Bigger Internal mass you will have with the vmax bottom end.
Re: SRX 440 project
I will trade you some New #8M6 Pistons W/Rings . For some other Pistons You can PM me for more information.
Re: SRX 440 project
Justin that has the SRX 500 told me that the bottom ends for the SRX 440, 500 and vmax 540 are all the same. My friend had a SRX 440 with a 540 bottom end and i think it worked well.
Re: SRX 440 project
Yes. They have the same Stroke 64mm. But they have different Bearings on the Crank. If you take a look in both end of their Cases They have differences to each otherchrisrider63 wrote:Justin that has the SRX 500 told me that the bottom ends for the SRX 440, 500 and vmax 540 are all the same. My friend had a SRX 440 with a 540 bottom end and i think it worked well.
They don't share the same seals and the Cases will not fit from each other. For example you can't take an upper case of the SRX500 And put it on the Lower case of the Vmax. Same with the SRX440. Maybe the Connecting Rods are interchangable for them.
I can be wrong. But i have them all and i have looked at them. But if you doubt it i will go and take some pics of them and post them to you.
Re: SRX 440 project
I also have a 440 & 540 and yes they are different, but I would like to see pictures of the 500 compaired to the other two just to see what it looks like..
Re: SRX 440 project
Hello. I will trade you some New NOS Yamaha #8M6 Pistons W/Rings for New NOS Yamaha #8R9 Pistons W/Rings
Re: SRX 440 project
Couldnt you just buy them from Justin yourself??
Re: SRX 440 project
Yes. Probably. I can sell you some#8M6 Pistons if you need that. i will PM You.chrisrider63 wrote:Couldnt you just buy them from Justin yourself??
Re: SRX 440 project
Doesnt Justin have a 540 bottom end on his SRX 500 drag sled?? THats what i was told and also i believe the SRX 440 bottom end, SRX 500 bottom end and the V-MAX 540 bottom end are the same Cubic Cetimeters.
Re: SRX 440 project
There were a few SRX 500 sleds here in SWEDEN that put the 540 Top End on the 500 Bottom end after running out of Pistons and Rings. But they got dissapointed in loss of power. That getting slower but after some porting of the 540 Jugs to nearly 500 specs they started to move againchrisrider63 wrote:Doesnt Justin have a 540 bottom end on his SRX 500 drag sled?? THats what i was told and also i believe the SRX 440 bottom end, SRX 500 bottom end and the V-MAX 540 bottom end are the same Cubic Cetimeters.
Re: SRX 440 project
Ok guys i now have 3 CDI boxes that i got from someone that was cleaning up there garage. THe last two numbers on 2 of the CDI's is "38" the other is "39" both number series start with 8R9.
