THE GREAT 3:16 SCREWED UP. lol. 3:16
alright guys, i,ll take raze,in. my 83 vmax was on my trailor. i loaded a lawn mower up on to do some cutting at my neigbors, than to take my youngest daughter to work. one problem i never shut fuel off. now shes beyong flooded and will barely bark. did all the tricks i know, anybody have this problem. way in here. 3:16
Re: THE GREAT 3:16 SCREWED UP. lol. 3:16
I have two sets of carbs one of one set does this no matter what I do, new needle and seat checked everything. I'd have to pull the pipe and dump them out. then let it dry. I did stand the sled up and let the fuel pour, yes pour out the ex port.
At the races I see the Bulldog (really modded engines) Kitty cat racers use a shop vac to suck air threw, always waited for the boom
I don't see why it wouldn't work if you used a blower to push air threw and dry things out
On mine I just waited a day, if ya have time that should do it. I had times where we turned shifter karts upside down and pull engine over till it was dry. If ya go that route, post pic's
LET IT SIT FOR TWO DAYS WITH FUEL VALVES OFF. FIRED RIGHT UP LAST NIGHT AND RAN GREAT. LESSON LEARNED. 3:16
when ever i get one that does that i take the pipes and carbs off and the plugs out.. then shoot compressed air in the pulse line port while your turn the clutch... a spray of gas comes out everywhere and generally it gets cleaned out pretty fast... its just a pain to take all that stuff off and put it back on
