'73 SR292 turn key racer
crwdog
Post by crwdog »
The time has come to sell my 73SR. This is a 643 chassis; rear close off panel, full length reproduction seat; SM292 gas tank; Phazer skid; Kimpex "R" track; original steering post and bar, but they are bent and have a hoop for ovals; steering hoop is not original as I had to replace it; phazer chain case with hydraulic break; Label X pipe; aluminum lube tank mounted on tunnel right rear; lube system is pressurized by exhaust-no pump or gravity feed; GPX spindles; Northstar Ski's; original bumper and hood hinges; GP292 bottom end; SM292 welded-trued-balanced-polished crank; GPX bell housing; GPX recoil; MSD ignition; SR292 cylinder-stock; NOS wiesco piston; ZRT600 reed cage; 44mm round slide; SR292 head; ISR legal clutch guard......... comes with a Spare piston (phazer); several NOZ head gaskets; gears, chains (single row gears/chains); Computer cable for MSD and dyno sheet
You know what these are worth! Make me an offer - Wedding bells in October!
go fast, turn left..look cool
