Vmax coil
Vmax coil
I was wondering if anyone would have a charge coil for an 84-87 vmax,it is the one for the handle bar warmers. The part # is 8X6-85521-10-00,it is the top one on the side that has two coils on top of one in other in the stator. If so please PM me with a price . Thanks
Joe
Post by Joe »
What happened to the original one?
My lighting coil went out a couple months ago. I took the stator out and found the wire had broken off the coil. I unwound the coil and found that it had 40 feet of #18 wire and the middle third had burned the insulation off the copper. The wire had dents in it and it looked like a failure waiting to happen. I wrapped the core with Scotch 27 electrical tape and rewound new wire on the old core. Once the new wire was in place, I wrapped it with another layer of Scotch 27 electrical tape.
The tape is woven glass with a thermosetting adhesive. It gets hard as epoxy once it gets warm.
I tested the lights last night and they worked fine.
It took about a half hour to wind the coil.
Current sleds:
1986 Yamaha VMAX 540
1992 Yamaha Venture 480
1993 Yamaha Viking 540
1997 Polaris RMK 700
The coil burned out ,I tried to unwrap it but it just all fell apart ,no way to tell how long it was, I guess I could keep wraping until I get the right OHM reading. Do you know where to buy that kind of wire??
Joe
Post by Joe »
Here is the first item I found on a search. The price is more than we normally pay because it is much more rugged than we use. It will get you started on a search though.
http://mouser.com/Search/Refine.aspx?N= ... re&FS=True
http://www.belden.com/pdfs/MasterCatalo ... e/3.25.pdf
http://www.alliedelec.com/Search/Produc ... b=Overview
Lower right corner of the following catalog page:
http://www.alliedelec.com/Catalog/pf.aspx?FN=469.pdf
Note that heavier wire is available than listed on the catalog page.
Current sleds:
youll probably want to save the head ache and check out this site.....
http://www.psep.biz/store/yamaha_snowmo ... _parts.htm
