540vmaxwaterpump
John J
540vmaxwaterpump
Post by John J »
has anybody been able to put two seals in the waterpump? from my measurements it will not fit. anybody try using one seal?
Rickyamaha
Post by Rickyamaha »
I found a double lip seal of 10 mm instead of 13.5 like the original OEM
Also 2 single lip of 7 mm(=14 mm)
Will let you know the part # asap...they are in my garage
Richard
See the Sticky above "Infamous Waterpump Seal"
sxr1000
Post by sxr1000 »
Yes I have used two seals and you have to shave a little rubber off of the first seal and then shim the impeller slightly and it works.
