83 - 88 Stator the same?
zachalyse
Post by zachalyse »
Was the stator on the Vmaxs the same for all years?
Joe
Post by Joe »
If I understand it correctly: The later ones had a separate winding for the handlebar warmers whereas the early models used the same coil for both lighting and handlebar warmers.
True, the 85's up had a yellow wire with black stripe from the handbar warmer coil..
Joe wrote:If I understand it correctly: The later ones had a separate winding for the handlebar warmers whereas the early models used the same coil for both lighting and handlebar warmers.
