The Exciter and Phazer use different bars, where the throttle lever assembly is long on the Exciter and shorter on the Phazer. For which sled do you need the airbox ? By pods do you mean a different gauge setup ?
Sorry about that I need bars and throttle lever for the Exciter. See I bought it for $100. It had been sitting outside for two years. It has some front end damage,like the kind you get from a culvert. I'm hoping to straighten it out being I can't find a frame. I need airboxes for both pz480 and ex570. Pods are aftermarket air filters. Like cheap foam versions of a K&N filter.
