SRX440 Pipes VS Vmax 540 Pipes.
SRX500F82
Post by SRX500F82 »
Hello. Have anyone of you who are a owner to a SRX 440 tried a set of Vmax 540 Pipes on the 440 Motor. If so what are your Comments. Did it run stronger with higher revs on top. Or better low performance. and MPG lower or higher. Compared to stock pipes. The 540 pipes seems to have bigger volume. Thank You Michael.
SRX500F82
Post by SRX500F82 »
O.k Guys don't be Shy, But be nice to tell me your secrets here :wink: Yammiegod. You must have tried something like this with your 81 srx. To beat the 77srx in a 660ft race. or did you run it stock all the time? Thank You Michael.
Micheal, the Vmax is set up to run 8200 rpms and the SRX's has the following pipes, clutching and ignition is set up to run ~9000 (?). It would be interesting to see if the SRX would run stronger in a short run with 540 pipes but, I'll bet it would lose some top end ?
