Interesting Read !
Interesting Read !
http://snowmobiles.yamahablogs.ca/categ ... explained/
May 8, 2008
Another Cranky Smoker
Well this week it’s time for me to come clean on some more SRX stuff. Lets start with the name. I was dead set against using SRX based on my experience with the infamous 1981 model debacle. For those who don’t know or may have heard the rumors. The 82 SRX production run (or Vmax as some would have it) was canceled in the name of damage control and to cannibalize the crankshafts for owners of the ill-fated 81’s. Reason being an unfortunate combination of clutch / crankcase assembly and carburetors doomed the TSS SRX to a life of broken crank-shafts. The name was dropped along with the engine and styling, to return as the first V-Max 540 in 1983.
I’m not particularly superstitious, but the thought of naming our new performance sled after the 81 cylinder grippin’ crank-eater seemed somewhat of a marketing Faux pas . But my thoughts didn’t matter because we could not seem to come up with a better name, plus the US guys seemed quite good with the SRX handle and so it was born. The irony in all of this came to light shortly after the first pre-pros hit the snow. Reports of a nasty vibration in the running boards trickled in, which spread quickly into the handle bars… uh-oh. -Long story short-… a welding booth was set up at the end of the crank assembly line and every new SRX crank was hand checked, trued if required and the end pin spot-welded before proceeding. As far as I know, this was the first (and only) time we had a production crank, welded at factory.
I had a good ‘I told you so…’ over some pints with Rit and Greg, but fortunately our crank woes of the 81 never manifested in the new SRX and the engine went on to prove itself quite bullet-proof.
