81 clutch removal
davet
81 clutch removal
Post by davet »
Hi Guys, not done this before, removing the primary.
The bolt is out
The Puller is in Tight
Do i use an impact gun ?
or do I whack the puller with a hammer....i tried the hammer and I cant tighten the puller anymore....clutch wont budge.
Dont want to wreck or strip anything
thanks
davet
Post by davet »
I got it off
filled the clutch shaft with Grease, put the puller in , used the hydraulic pressure to pop it off.
impact gun alone didnt work
