Honda CR 80-85 Parts
Posted: Fri Mar 28, 2008 11:52 am
Hello, the majority of these parts are from what I was told is a 199(8?) CR80 which was in boxes so, I had no way of testing ! I’ve tried to keep the prices reasonable but, with PayPal and shipping fees so, high I do not want to loose money ! If you are unhappy with any part simply return it and I will refund your cost Minus the shipping and PayPal fees. I take PayPal or Money orders. Email me for pictures chkinetics@csonline.net
Thank you !
Chuck Schettler
Shippenville Pa.
814 226-1595 M-F 7-2 Eastern time
or
814 354-2687 Eve/Wknds.
-2003 CR85 Exhaust and muffler (Small dent) $25.00
-1998 CR80 Exhaust $20.00 (a couple small dents)
-1998 CR80 Handle bars steel $ 18.00
-1998 CR80 Gas Tank with valve and side cover $22.00
-1998 CR80 Air box I have a couple new filter skins I will add in ! $20.00
-1998 CR80 Front Brake reservoir, line and caliper (Lever has bow) $30.00
-1998 CR80 Frame I see no cracks or welds $55.00
-1998 CR80 Throttle block, cable and carb slide (Plastic throttle tube has kink but, slides on bars and works ok) $22.00
-1998 CR80 Front forks, Struts have no gouges, Upper tubes have small scratches with ProAction valve body & Pro X Genuine Racing Part Stickers (I have no way to tell what the actual parts are inside?) my guess is they probably need seals ? $175.00
-1998 CR80 Rear brake lever, piston, hose and reservoir $30.00
-1998 CR80 Bottom end & clutch basket, includes everything you see in the picture. I have no idea if any parts are missing ? I see 1 fork wye is broken. $42.00
-1998 CR80(?) 2 Ignition coils, Stator and pickup coil ? $40.00
-1998 CR80 Radiator with hoses ( No cap and unit has slight lengthwise bend) I see no cracks. $22.00
-1998 CR80 Top clamp $25.00
-1998 CR80 Rear Takasago Excell Rim with bushings/spacers(?), 49 tooth steel sprocket, has 3 loose spokes and light scratches, worn Chin Shin 4.10-14 tire $45.00
-1998 CR80 Front rim with axle bolt and spacers, 1.40 x 17 &06- -1 07- -
markings, ¼ tread Chin Shin 3.00-17 tire, $42.00
-2003 CR85 Front rim (with very slight bow in lip of rim) unit was used by my son and worked fine, with Michelin Starcross MH3, 70/100-17 tire ¾ tread $42.00
-2003 CR85 Good Rear rim and spokes (with broken hub), J14 X 1.60 & 92 2014
11- - markings, Michelin Starcross ½ tread $32.00
Thank you !
Chuck Schettler
Shippenville Pa.
or
