Silencer Vmax is Bogging & Hesitating
Posted: Sun Feb 24, 2008 8:34 pm
My 1990 Vmax was recently all tuned up but I still have that bogging feeling and sound. It also seems like when I give it more throttle it gets weaker and just sounds even different from my other one that I have. I can get some good speed but most of the time it feels and sounds like it is hesitating.
Could this be cause from the "Silencer" being plugged from somthing? My mechanic took it off from the pipes and it ran crappy as they all do when it is off then he put it back on and it seemed to be gone. I got it home and it seemed ok for about 20 minutes then the same thing happen again. Sometimes even if I am climbing a small incline (hill) it would bog out and I would have to get off and feed it gas off and on and with no weight on the sled to get it going. The plugs look good alittle wet.
So again I am asking do you think it could be the "Silencer" has anyone had this same problem happen to them.
This seems to really have us stumped. Again the sound of the pipes don't sound the same as they used to and definitely don't sound the same as my other one which sounds great and the way this one used to sound.
Has anyone ever open the inside of a silencer or know of a way to clean one out in case there is somthing in it causing this fluxuation in back pressure which we think might be the problem here.
Again I am not looking at taking it off as I know it needs to be on for the proper back pressure but has anyone had this same problem we seem to be stumped on this issue
Thanks for the help[/b]
