Radar Runs
Everyone loves to check out special events. This area is for posting about races, shows, swap meets, and basiclly any event you think others should know about!
Undertaker#13
Radar Runs
Post by Undertaker#13 »
Well just got Maximum OverDrive all loaded up heading to the races in the mourning!
Good luck altough, with your track record....... sounds like the competion needs the luck ! ! ! :)
Undertaker#13
Radar Runs
:shock: Old Maximum OverDrive held them off. I won with 91.3 in 1000ft! They had a Turbo Charged RX-1 That Yamahaed the field with the Fastest speed of the day! 135 mph in 1000ft That my man is hauling A$$!!!!!!!!. It seem good to see some other Yamaha's racing 8) ps I'm kind of running out of trophy space :roll:
jipcee
Post by jipcee »
Nice job!
Undertaker, what are you using for clutch spring and arms?
What twist are you using on your secondary?
What is your gearing?
Thanks................jipcee
