Primary Clutch spring ?
ThePipe
Post by ThePipe »
What tension do I need for my 1983 540 for it to engage at 5,000 RPM
Back in the 90s I bought a spring for my 1986 that engaged at 5 grand but over the years my memory has slipped.
Lee
southarisin88
ummm
Post by southarisin88 »
I run the gold spring in mine for 4400rpm but my uncle runs a blue spring and he gets abdout 4800 out of his.
The Comet Purple #207758A is around 4500rpm
See
http://www.hoffcocomet.com/comet/spring-engagements.asp
SRXfromHELL
engagement
Post by SRXfromHELL »
hoffco comet has engagement specs listed on there site by cam arm to spring if your running N weights you'll never get there use B weights will net you 4900 a spring shim will get you about 200 more rpm
Kevin
