Vmax540 wrote:Round up the Posey boys looks like we have a hanging to do..........
No sweat, every one thats is parted keeps others running and makes ours more valuable ! Your pump seal may last a lifetime but, you never know ! I really need to take one of the 83 waterpumps apart and take a seal to a bearing/seal outlet and see if I can get them cross referenced or matched. Has any one tried and can it be doneto retofit these to the newer style shaft and seals ?
Thanks for the input Sheriff
,, just to verify, it's actually the seal that keeps the coolant out of the speedo and pump drive case then, not the "crankcase"?
I've looked at the little dip stick several times and didn't see anything but oil,, didn't ride
the thing much once I got it going due to it being summer time and I ran out good grass
fairly fast. Then I tore the poor thing all apart
dastardly act it was.
Thanks again for the timely info and if you find a seal that will work, I'm sure it will be
posted,, neat site you have here,, I have rode most of the 78 to, well ,when the first
Phazer was made of Yamaha's. They weren't mine but some guys that I worked with and that 78 or 79 SRX L/C was a REAL eye opener! Unbelievable high end power.
