Fuel System Info on 85 vmax
Since im new to the vmax i have a question on the fuel system that the vmax has. Now i see 2 fuel pumps, vent tubes that connect to the pumps and to the carbs. I just dont understand why or how that is supposed to work properly with the muiki carbs that are on it. Im just looking for info thats all so i can better understand what i have.
Yamaha's advertized logic was 2 fuel pumps insure needed fuel flow requirements ! Which, as we all know was unnecessary and not used on later sleds ! Altough, it works I have always wondered what happens to the engine if 1 pump quits working ?
Re: Fuel System Info on 85 vmax
your not getting confused witht the pulse lines that connect the pumps to the crankcase are you?zeroburn wrote: vent tubes that connect to the pumps and to the carbs.
agreed, the only t's in the fuel lines should before the pumps for the oil injection
