PORTING PROBLEMS !
Posted: Wed Dec 19, 2007 8:52 pm
Hey Guys i followed the porting specs as listed in the arcticals lower intake 4 mil ext. . . I got my V max running today it had 290 jets in it to begin with i figured with the porting i should go up so i went to 320 , got it started but it would bog the whole way , So i went into the shop and looked at the plugs , REALY black , So i moved the carb needle jet to the top clip to lean it out , After that It will still bog from 3800rpm - 4400 rpm then it kicks in hard and goes realy fast , and the plugs look good , what do yous think i should do , , , i was thinking maybe 300s and move the needle to the stock middle grove ?
Any help would be great
Im sure some one on here has used these porting specs
Chris
Chris
