				'81 SRX reverse cam secondary
				Posted: Wed Feb 18, 2015 12:50 pm
				by Yam429
				I have an '81 SRX 440 with a comet 108 primary. I have heard that I will need a reverse cam secondary off of a '95 or '96 vmax in order for it to run right. Is this true & will this secondary slide right on or will I need the '95 vmax jackshaft as well? Does anybody know what spring & weights I should be running with this setup? With my current setup (108 & stock secondary) I can only get 42 mph out of this sled at 5500 rpm. Thanks, Reed
				Re: '81 SRX reverse cam secondary
				Posted: Wed Feb 18, 2015 8:49 pm
				by vmax-540
				Yes the reverse cam off of the newer Yamaha's will fit your secondary shaft. Start with N1 weights and the purple spring in the comet, you will need to clutch it to run at 9000-9250 rpm's. This should get you started..
				Posted: Thu Feb 19, 2015 9:03 am
				by Yam429
				Perfect, I'll try that. Thanks Jeff
				Posted: Thu Feb 19, 2015 9:26 am
				x2 on Jeff's reply.  Loads of good reading here
viewtopic.php?f=2&t=1506
				Posted: Thu Feb 19, 2015 10:25 am
				by Yam429
				Which purple spring in the 108? There are two a 207758 or 207888.
				Posted: Thu Feb 19, 2015 11:06 am
				Posted: Fri Feb 20, 2015 11:39 am
				by chrisrider63
				so I could use a polaris primary and vmax 500 new style secondary for the 81 srx? And/or yamaha clutch awesome!!! Never thought of this. Doesnt it need to be cut or something?
				Posted: Fri Feb 20, 2015 7:46 pm
				by vmax-540
				Use the 207888, it should get you in the ball park..
				Posted: Fri Feb 20, 2015 8:40 pm
				I used a new Polaris on mine and cut the 83 sec to open more. Phil had a post on here somewhere which turned me on to the trick.
				Posted: Fri Feb 20, 2015 9:34 pm
				by Yam429
				Shoot I just got the purple 207758A spring delivered to my door today. Am I going to want the purple 207888A instead? How much of a difference is there?
				Posted: Fri Feb 20, 2015 11:20 pm
				Yam429 wrote:Shoot I just got the purple 207758A spring delivered to my door today. Am I going to want the purple 207888A instead? How much of a difference is there?
viewtopic.php?f=2&t=1506&p=9822&hilit=purple#p9822
