1983 V Max 540
Posted: Thu Feb 20, 2014 4:56 pm
For Sale: 1983 V Max 540
Fresh engine from trued crank to fresh coated cylinder
Updated porting
Updated water pump housing (all new seals and bearings) with red dot oil pump
Custom secondary fuel tank for another 2 gallons
New seat cover
3/4" lug track
New front and rear shock on rear suspension last year
Rear suspension all new bearings, all bushings custom made on my lathe, grease fittings added at every pivot (2yrs ago)
Custom recoil that uses the single plastic pawl instead of the original 3 metal pawls
LED tail light
New lighting coil last year
P85 clutch with newer Yamaha secondary
This sled is currently licensed and on the trail. I have put on just over 130 miles this year on the new engine and put on around 1000 miles last year. Original hood has some minor spider cracks, belly and sides have some wrinkles and dents. Dash has some fading. Along with sled comes a front sway bar, good CDI box, engine bottom end, and a stripped chassis. Sled is located in Kane, Pa $1200 call 814 778-5348
Updated porting
New seat cover
3/4" lug track
LED tail light
