Here are some new in box Yamaha parts I have for sale.
The first row is how many I have in stock, the last row is the price in Norwegian krone. US/Canada customers give me an offer. You pay for shipping.
I also have 9 used Vmax 540 cylinders need resleeving, 5 used cylinder heads, 5 used crankshafts some of them in bad shape, and some more used parts.
But this list is of new in box parts.
6 STK 89N-11351-00-00 Gasket, Cylinder
SS 440, EC 540, SRV 540, XLV 540, Viking
30 stk 857-11351-09-00 Gasket, Cylinder
SW, GP, SS, SL, EL, GPX, TL, TW, EX 440
11 stk 8F3-11181-01-00 Gasket, Cylinder Head
GP 246, ET 250
12 stk 8F3-11181-01-00 Gasket, Cylinder Head
EX 440, GP 440, PR 440, EX 340
3 stk 8AB-13621-00-00 Gasket, Valve Seat
EX 340, EX 440,GP 440,PR 440
26 stk 828-11181-09-00 Gasket, Cylinder Head
GP, SR, EX, PR
6 stk 8R4-14613-01-00 Gasket, Exhaust Pipe
BR 250, Bravo 250
21 stk 881-11351-02-00 Gasket, Cylinder
GP 246, ET 250
3 stk 8R4-11351-04-00 Gasket, Cylinder
BR 250, Bravo 250
5 stk 8Y2-13563-02-00 Gasket
ET 340, Enticer, Ovation, ET 410 CS 340
2 stk 89X-11351-00-00 Gasket, Cylinder
Enticer 2, ET 410
2 stk 88F-11351-01-00 Gasket, Cylinder
Phazer, Venture
25 stk 866-13563-09-00 Gasket
GP 443, GP 440, EX 340, EX 440, PR 440
3 stk 93109-63044-00 Oil Seal
Phazer, Inviter, CF 300, Ovation, CS 340
4 stk 8CH-14613-01-00 Gasket, Exhaust Pipe
SX venom, Venture 600+700, Mountain max 600+700,Vmax 600+700
3 stk 278-11181-01-00 Gasket, Cylinder Head
RD 350, TZ 350 (MC)
4 stk 810-14545-00-00 Diaphragm
GP, SL, SS, SW, SR, EL, EW, GPX, SM, ET 250
12 stk 8M6-12435-04-00 Gasket
SRX 440E, SRX 500F, Vmax 540
3 stk 8DF-14613-00-00 Gasket, Exhaust Pipe
SRX 600 + 700
1 stk 8CR-11181-00-00 Gasket, Cylinder Head
Vmax 500 + 600 + 700, Venture 500 + 600
2 stk 10V-1362125
1 stk 93109-53036-00 O-Ring
Vmax 540, SRV, EX 570, Phazer, Venture XL, Vmax 500 + 600, ET 410, Viking 3
1 stk 8F3-14613-01-00 Gasket, Exaust Pipe
ET 250, SRX 440, Inviter, CF 300
4 stk 93103-36117-00 Oil Seal
SRV, Vmax 540, EX 570, Phazer 2, Vmax 500 + 600, Venture, Viking 2+3
2 stk 8CR-14613-00-00 Gasket, Exhaust Pipe
Vmax 500+600+700, Venture 500+600
1 stk 8CR-12439-00-00 O-Ring
2 stk 93109-53036-00 O-Ring
Vmax 540, SRV, EX 570, Phazer 2, Viking 2+3, Vmax 500+600
1 stk 126-13116-01-00 Gasket, Pump Case
GP 443, ET 250
2 stk 82H-77223-00-00 Fastner
SRV, SS, BR, ET, XLV, Ovation, Vmax500+600+700, Viking
1 sett 8AB-11603-01-00 Piston Ring Set (Std)
Vmax 500+600, vEnture 500+600, SX 500
1 sett 8CA-11603-00-00 Piston Ring Set (Std)
Vmax 600
2 sett 8F3-11601-20-00 Piston Ringset 2Nd ALTERNATE PART
ET 250, EC 540, SRV 540
1 sett 8F3-11601-40-00 Piston Ringset 4Th ALTERNATE PARTS
1 sett 8G8-11601-00-00 Piston Ring Set (Std)
ET 340, Ovation, CS 340
1 sett 8G8-11601-20-00 Piston Ring Set (0.50Mm O/S)
3 sett 8K4-11601-00-00 Piston Ring Set (Std) STD
SS 440, ET 400, ET 410
1 sett 8R4-11610-00-00 Piston Ring Set (Std)
BR 250, BRAVO 250
2 sett 8R6-11601-00-00 Piston Ring Set (Std)
SRV, XLV, CF 300, EX 570, VIKING 540
1 sett 8V0-11601-00-00 Piston Ringset Std (Std) UR STD
Phazer, Venture
2 sett 8V0-11601-20-00 Piston Ringset 2Nd (2Nd O/S) ALT. PART
Phazer, Venture
4 stk 93306-28202-00 Bearing200
Vmax 600+700, Venture 600+700, SX Venom, Mountain Max 600+700
1 stk 93306-20716-00 Bearing
EF 5000, EF 6000
1 stk 93306-30627-00 Bearing
Viking 540
1 stk93306-30561 93306-30571 Bearing
Vmax 4, Ovation 340
1 stk 93306-30707/ 30711/ 30718 Bearing
EX 570/2
1 stk 93306-20643-00 Bearing
Vmax 4
2 stk93399-99908-00 Bearing, Special
Phazer
1 stk 8CR-11428-01-00 Bearing
Vmax 500+600, Mountain Max 600+700, Venture, SX
7 stk 82M-11636-00-00 Piston 2 O/S 0.50 (0.50Mm O/S
EX 570
2 stk 82M-11681-00-00 Pin, Crank
EX 570, Vmax 500+600, SX 500, Venture
2 stk 8H8-11681-00-00 Pin, Crank
EC 540, SS 440, SRV, XLV
2 stk 857-11681-00-00 Pin, Crank
EW, GP, EL, SL, TW, EX 340+440, GS, ET 250, BR 250, PHAZER, VENTURE, INVITER
1 stk 8G8-11681-00-00 Pin, Crank
ET 340, ET 410, Ovation
3 stk 93310-422L0-00 Bearing
ET 340, Ovation
4 stk 93310-316B2-00 Bearing
ET 400, ET 410
4 stk 93310-216L2-00 Bearing, Cylindrical
ET 300
1 stk 93310-523D2-00 Bearing, CylindricaL
Vmax 4
1 stk 93310-42497-00 Bearing, Cylinder
SL, SW, GP, GPX, EX340+440, ET 250, SS 440, BR 250
6 stk 90209-22248-00 Washer, Special Shape
ET 340, Ovation
3 stk 8A7-11685-00-00 Washer, Crank Pin
SRX 440, SRV, Phazer, Venture
1 stk 82M-11685/90209-25325 Washer, Crank Pin
4 stk 90387-106J3-00 Collar
Phazer, EX 570, Venture
2 stk 34X-11651-00-00 Rod, Connecting
ET 340, Ovation
1 stk 8A7-11651/838-11651 Rod, Connecting
SL, GP, EW, EL, GPX, EX 440, SS 440, SRX 440
1 stk 8H8-85513-20-00 Coil, Lighting
EC 540, ET 340, Phazer, XLV, EX 570
1 stk 80L-47480-00-00Shock Absorber
Phazer, XLV
30 stk 93103-32156-00 Oil Seal
SL, SW, EW, GP, SR, GPX, SRX, SRV, XLV, Viking
1 stk 82M-12481-00-00 Pipe
1 stk 90508-50654 Spring, Torsion
Phazer
4 stk 93102-20447-00 Oil Seal
ET 250, ET 340, BR 250
2 stk 93102-35473 Oil Seal
Vmax 600+700, Apex
2 stk 93103-10168 Oil Seal
YZ 80+125
3 stk 93102-33140 Oil Seal, Sd-Type
GPX, EX 340+440, SRX 440, EC 540, EX 440
8 stk 93102-36232 Oil Seal
SRV, VMAX 540, EX 570, PHAZER, Venture
1 stk 93102-40080 Oil Seal, Sd-Type
SW, GP, EW, EL, SL, SM, ET 400
1 stk 93102-30112 Oil Seal, Sd-Type
SM, GS
5 stk 93103-32155 Oil Seal
Phazer, Venture
20 stk93103-32153 Oil Seal
EX 570, Vmax 500+600, Venture, SRX 600+700
20 stk93102-30128 Oil Seal, Sd-Type
GP, ET 250
3 stk 93102-30184 Oil Seal, Sd-Type
ET 340, Enticer
1 stk 93104-06033 Oil Seal, So-Type
SL, EW,GP,SR, TL, TW, SRX 440E, ET 340, EC 540
1 stk 8E3-47413-00 Frame, Sliding
GS,GP, ET 340, Enticer, Bravo
15 stk90387-13758 Collar
SRX 440E, SRV, SS 440
10 stk8F3-15715-00 Spring, Friction
ET 250, ET 340, SS 440, SRV, XLV, BRAVO
1 stk 81E-85110 Reflector Assembly
EX 570, INVITER, Vmax 4, Venture
5 stk 8F3-15734 Spring, Return
ET 250, ET 340, SRV, XLV, Phazer, Bravo
1 stk 8F3-15716-03 Plate, Drive
EC 540, ET 250, ET 340, SS 440, SRV, Bravo, Phazer
2 stk 82M-15716 Plate, Drive
EX 570, Venture, VMAX 500+600+700
2 stk 8F3-4551 Housing, Front Axle
ET 250, ET 340, BR 250, ET 400, Inviter
2 stk 8G5-47551-1 Housing, Front Axle
ET 250, ET 340
1 stk8V0-23814-01 Holder, Handle Upper
Phazer, EX 570
1 stk 84G-25730 Caliper Body Comp
ET 340
2 stk 885-47457 Damper
GPX, EX 340+440, GP, PR, ET 340
10 stk8A5-47113/ 89A-47113 Plate, Reinforcement
SRX 440E, SRV, XLV, Bravo, ET 250, Phazer
1 stk 82M-2198F Cover 1 (L.H)
1 stk 82M-12483 Pipe
EX 570
1 stk 36Y-15426/ 5EA-15426-20 Cover, Oil Pump
FJ 1100, FJ 1200
