2 1981 SRX Hoods and 2 1981 SRX Motors,Carbs
Posted: Fri Jan 03, 2014 6:30 pm
				I have 2 1981 SRX hoods that have been restored and painted black one has no decals and the other has the 5 warning and caution decals in place behind the windshield area. I have the 93 octane decal the large Attention Decal and 2 large gray YAMAHA decal NOS if anyone is interested separately. Both have the aluminum radiator shroud riveted in place the rest of the decals and headlights etc are not there although I probably still have these just not accessible to me this time of year in cold storage.$100 for each hood decals negotiable.
I also have 2 motors, they are both complete except for the clutch and carburetors. One has the cylinders,pistons and head removed, I inherited it in this condition from a guy in NY with a sled that was in pieces. He told me it ran before he took it apart but I have no way of verifying that. The pistons are original 8M6 parts but the rings have some rust from storage, I have a set of aftermarket pistons to put in if desired. There is no serial number stamped on this block.$100 + $50 for the pair of new pistons
The other motor is together and turns over, but again I got it off a parts sled that was not worth restoring it is stamped 437002245 but does not look like the stamping on my original 1981 SRX.$100
I also have a pair of butterfly carbs for the 81 I was going to go through them and keep them as spares but stripped out the pilot jet slot when trying to remove it they probably need to be soaked prior to disassembly.$50
Let me know what you might be interested in and I can send pictures.
