comet clutch
SSDSTS24
comet clutch
Post by SSDSTS24 »
I have 3 1985 vmax and i went to pull off the clutch on 2 of them and found 1 takes a 9/16 x 18 puller and the other takes 5/8 x 18 puller so am i right by thinking 1 is a 94c and the other is a 108? Witch one came stock on the sled when new? Witch one would be the one to use?
Re: comet clutch
102's.......
viewtopic.php?f=2&t=1506
viewtopic.php?f=1&t=2223
-Clutching
http://www.hiperf.com/acatalog/cometcalguide.pdf
http://www.hiperf.com/acatalog/Snowmobi ... ts_84.html
Comet Clutch, Spring 8U9-17643-10
http://www.vintagevmax.com/vvforum/view ... =5513#5513
Yamaha V-Max--30mm Shallow Tapered Bore
Code: 217506
(Fits `83-87 V-Max, `81 SRX) This clutch comes set up for 1-1/4 belt width.
http://www.psep.biz/store/yamaha_snowmo ... _parts.htm
http://www.vintagevmax.com/vvforum/view ... hlight=102
http://www.snowtechmagazine.com/article ... epower.php
http://cgi.ebay.com/ebaymotors/ws/eBayI ... MEWNX%3AIT
The clutch puller which it says is for the Yamaha Comets you can see here.
