I will not use the air box but *K & N* filters. Please any help appreciated.
38 mm carbs to replace original 8M6
Rickyamaha
I know it is an old question but I am replacing the original carbs by Mikuni round slide 38 mm and would like to know with what parts inside to have a safe runner.
Re: 38 mm carbs to replace original 8M6
I have never ran one without an air box but, I would start richer than stock.
Carburetor- Mfr.- Type/ Size/ Qty/ ID Number Mikuni- VM38/ 38mm/ 2/ L:80N-00 R:80N-00
Main Jet/ Main Air Jet 290/ 2.5
Slow Jet/ Slow Air Jet/ Air Screw �/ �/ �
Pilot Jet/ Pilot Screw (Turns Out) 40/ �
Needle Jet/ Jet Needle- Clip Position/ Cut Away/ Air Jet Q-0/ 6DH1-4/ 3.0/ �
Power Jet/ Power Air Jet L:135 R:130/ L:1.5 R:1.4
Fuel Inlet Valve/ Float Level 1.5/ 18.1mm
Idle Speed 1500 rpm
VMX 540 K High Altitude Specifications
Standard Settings High Altitude
Idle 1500 rpm Standard
Clutch Engagement 4000 +/-200 rpm 4200 +/-200 rpm
Shift Speed 8200 +/-200 rpm Standard
Main Jet # 290 See Setting Chart
Slow / Pilot Jet # 40 Above 6000 ft: # 45
Pilot Screw 1/2 Turn Out Above 6000 ft: 1.0 turn
Jet Needle Clip Position # 3 # 3 or As Needed for Response
Idle Speed 1500 rpm
Rickyamaha
Lucky I am. I do have 2 80N carbs with the original air box..!! That should do at best.
Thanks for the great info.
Richard
Richard
Just curious as to what calibration if you are using 38's from polaris that do not have power jets?
