Clutch Puller Issue
Posted: Sat Feb 18, 2012 2:01 pm
by fastcar01
Years ago I had to replace my original clutch, I got a 108EXP to change it to (which I am repalcing now). The puller that I used on the orginal one was a bit short, so I put a dowl pin in the crankshaft, which worked. Now years ago, I had to pull that 108 and what a PITA. I bent two pullers before I finally popped it. I am not sure if the dowl pin let the puller slip over a bit, but I guess bottom line is, is there a different puller I shoudl have used?
Re: Clutch Puller Issue
Posted: Sat Feb 18, 2012 3:26 pm
Did you try tilting the sled on the rt side and adding a little heavy oil or grease to the inside of the hole before threading in the puller ?
Lots of different pullers.
http://www.ebay.com/itm/Clutch-Puller-C ... 32&vxp=mtr
http://www.ebay.com/itm/Clutch-Puller-f ... 75&vxp=mtr
http://www.ebay.com/dsc/i.html?LH_Title ... &_osacat=0
