How do you adjust clutch center to center? Do you have to slide the engine? Does it have adjustemnt holes?
center to center adjustment
Re: center to center adjustment
Lightly loosen the four mounting bolts. There is enough wiggle room. Offset is changed by moving (exchanging) the washers/shims from the backside or outside of the secondary clutch.
Drive- Engagement rpm/ Shift rpm 4000 +/- 200 rpm/ 8200 +/-200rpm
Belt Length/ Width/ Wear Limit/ IBM Number 1175mm/ 31.6mm/ 26mm/ 8M6
Sheave Center to Center/ Offset 305 +/-1.0mm/ 11 +/-0.5mm
Primary Spring Color/ Length/ Rate/ Preload Pink/ 75.5mm/ 2.31Kg-mm/ 32.8 Kg
