clutch match up?
Posted: Fri Jan 07, 2011 7:47 pm
by sledheadkevin
i just bought an 89 (i think) vmax. i am going to put the thing back together but am wondering if the clutches off of an 84 phazer will fit. i just have parts from my phazer that i am hopeing that i can use please let me know also i have been looking for the oil injection on the sled but cant find it im not sure if it has been taken off or not where is it located/ the oil resevior?
Re: clutch match up?
Posted: Sat Jan 08, 2011 1:40 am
sledheadkevin wrote:i just bought an 89 (i think) vmax. i am going to put the thing back together but am wondering if the clutches off of an 84 phazer will fit. i just have parts from my phazer that i am hopeing that i can use please let me know also i have been looking for the oil injection on the sled but cant find it im not sure if it has been taken off or not where is it located/ the oil resevior?
Give me the vin# and I can tell you the year of your sled. The secondary clutch off of an 84 phazer should work but, the primary offset would certainly be different ? The oil pump is on the back right hand side of the engines gear case assembly under neath the radiator and oil tank.
Posted: Mon Jan 10, 2011 1:41 pm
by sledheadkevin
ok well ill work on getting the vin#. it looks as though the oil pump has been removed i see where it was. so what premix ratio should i run? i usually run a 50:1 in my two strokes or 40:1 what would be best?
Posted: Mon Jan 10, 2011 2:10 pm
by sledheadkevin
So what are some alternative primary clutches that i can use on this sled. i dont have all the parts for the one that is on it. so i am just looking at what i can put on there so that i can get this thing going on the snow to start out with. hopeing to do more to it later.
Posted: Mon Jan 10, 2011 9:26 pm
by agfirecat
I bought a vmax parts sled that had a polaris p-85 primary on it you should maybe see if u could score one off of a indy 500 or maybe an xlt i would measure the inside dia. of the back of your primary withh a micrometer and make a note of it when you go to get a clutch .(snowmobile bone yard). i can let ya know what spring and weights are in that clutch if ya want. id sell ya the clutch but it has a cracked sheave.
Posted: Mon Jan 10, 2011 11:33 pm
Tons, of reading right here in the Garage forum heck, there is a sticky on clutching......
viewtopic.php?f=2&t=1506
Posted: Sat Jan 15, 2011 7:54 pm
by sledheadkevin
Hey i was just wondering if a '85-'90 SRV,XLV,535,540 clutch fit on the Vmax? i saw a post for a clutch that im hopeing to buy and hope that it will work.
Posted: Sat Jan 15, 2011 8:13 pm
by sledheadkevin
another thing if i put an xlt primary clutch on can i put the secondary clutch on as well? will it match up/fit. cuz i know that the belt sizes are different so the stock secondary wont work with an xlt primary will it?
