JUGS FOR MY 1981 SRX E
messina1974
Post by messina1974 »
I am going through the process of rebuilding the motor in my sled as seals in the crank case have taken a dump. anyways I was wondering what the general consensus was on ball honing my jugs as there is some little minor pitting in the cylinder. These are original and have not been resleaved. my manual says NO honing so I guess that would answer my question, but I thought maybe ball honing would be ok as obviously it is not the same as a regular hone job. AND / OR what the consensus would be on lightly hitting them with some fine sand paper. I have purchased new pistons and rings well thanks for any help guys, MIKE
Re: JUGS FOR MY 1981 SRX E
I have used a ball hone for years with good results.
From Wiseco
-Chrome cylinder Honing
Wiseco recommends finish honing the cylinders with any where from a 240 to 400 grit, and recommend 280 grit as best. We do have a soft hone available that will do the job nicely. The part # is W6077 and will work for 63-76mm bores. You can find more information on our website at http://www.wiseco.com
Tom Davis x3109
Technical Sales
tdavis@wiseco.com
Wiseco Pistons Inc.
7201 Industrial Park Blvd.
Mentor, Ohio 44060
(440) 951-6600
messina1974
I thought that these cylinders were nickosil (spelling error) and not chrome bores? not real sure on that. but would that make a difference is honing
OEM Cylinders are chrome.
messina1974
Thanks for the info
