Right now i own a 1985 SRV and am wanting to put on a dual 38mm mikuni roundslide carb kit. Since it is hard to find a Reichard Dual carb kit for the SRV anymore i had another idea. What i want to do is take the carb mounting flanges off a Phazer since they were reed valve engines and with dual carbs. Then i will make a piece of rubber to angle the right hand carb since the SRV handle Bar rod is in the way. But i need your guys Vmax know how to help me.
First Problem: I want to keep my oil injection, so would it work to use a Vmax 540 throttle cable and oil cable but the problem is i dont know if they are the same and dont know how the Vmax cable works, Please give me your input.
Second: What jets do you run in the Vmax 540, and also i have my air box taken off so what jets would you guys prefer.
