I Need Everyones help and input..... Please !
Posted: Tue Jan 05, 2010 11:19 am
[Working on putting together a list of To and Not to do list and when it is complete we can get Tyler to put this into the Aritcles Section ? I would also, like to compile a list of clutching setups that people have submitted as a reference or maybe make a Clutching Forum ? Bring on the suggestion.... ! Thanks Chuck S.
-Yamaha Part diagrams
http://www.yamaha-motor.com/sport/parts/home.aspx
-Non working temp gauge (Tylers working on this)
-Thermostat
Either replace your old or remove the spring and plunger to avoid costly repairs. If gutting the thermostat remember Cold Seizure so, allow your engine to come up to temp before running hard !
-Cold hand warmers
Do you self a favor and get a can of expanding weather sealing foam then, drill holes in the end of the hand warmer grips just big enough to insert the cans nozzle then fill your handlebars. This will help retain the heat of the warmers and help deaden any handle bar vibrations !
-Recoil Failures
Make sure the rope is long enough, avoid pulling it out to the end and make sure it engages before pulling the rope.
http://cgi.ebay.com/ebaymotors/YAMAHA-S ... ccessories
-Fuel Tank cap hinge and/or tank neck breaking.
Push the catch with one hand and gently close the cap with the other hand.
-Windshield Replacement Do Not Overtighten and crack your new shield, simply tighten the lock nuts until they contact the shroud.
-Handle bar pad replacement Do Not Overtighten and pull the screws on this PLASTIC !
-Finding Rear Suspension Shocks
Search all the following sleds had the original Pro-Action Rear Suspension.
1983(?) to 1991 SRV 540
1983 to 1991 Vmax 540
1991 to 1993 Exciter
1992 to 1997 Vmax 750/800 with the exception of the 97 XT models
1994-1996 Vmax 5/600 with the exception of the 96 XT models
KAYABA INDUSTRY CO. LTD
Front of Rear suspension middle shock ~ 119/16" or 295m.m. C.C.
Rear ~ 14.5" or 366m.m. C.C.
1992Vmax4 Rear KYB 13D P# 8AX-47480-00 Infinate Preload
?Year Vmax540 Front/Middle KYB H22 P# 8V9-47481-00 Infinate Preload
?Year Vmax540 Rear KYB 2610 P# 8U7-47480-00 5 Position Preload
1985 Vmax540 Front/Middle KYB WF8 P# 8V9-47481-00 Infinate Preload
Kimpex Pro Gold Rear P# 04-284 Infinate Preload
-Head light dims when braking
Use a Red LED taillight bulb http://www.bluhmenterprises.com/product ... gory_id=29
-Lighting Coil
http://www.psep.biz/store/yamaha_snowmo ... _coils.htm
V-MAX 83-91 YAM VMX540 L/C ADLP010854 17.95
*I always make sure my headlight is off (Down Position) before starting and turning off the Vmax to avoid a surge on the electrical system. ** Hold your hand on the head light cover when releasing the latch to avoid the assembly from being jarred.
-Dimmer Switch
Do Not even bother with the Aftermarket rubber covers, they are nearly impossible to replace and tear easily.
DIMMER SWITCH Item Number:KX0112036
Manufacturer Item# 01-120-36 (D) Now $16.96
http://www.jrgraham.com:9081/browse...&ctg_id=7146445
-Painthttp://www.color-rite.com/
1987-VMX540-V-max
Factory Color Factory Code Color Rite Top Color Rite Base
Primary Color: Urushi Black 0JW 5320 None
-T.S.S. Maintenance
On every used T.S.S. sled I've bought the Knuckles and steel bushing are almost frozen or completely locked up and pivoting on the bolts ! I've bought sleds that the locked up joints won't even allow the springs to return let, alone the struts to work when hitting a bump. The T.S.S sleds have always gotten a bad rap for slop developing when the ungreased steel bushing's freeze up they grind away on the nylon washers ! I have sleds that are 15+ years old that have never had a bushing kit and are almost as tight as new. Just take the knuckles and the ski mounts apart every other year and grease !
Shim Kits http://s15106.50belowcommerce.com/produ ... oducts=tss
http://www.mfgsupply.com/m/c/100-650.html
-Off Season Storage
Drain your tank to ~1 gallon of gas, then add Stabil or any other gas stabilizer. Start your sled and allow time for the stabilizer to reach the carbs.
- Stators 5 different
1981 SRX (Original) P# 8K4-85500-10-00
1981 SRX (Updated) P# 8R9-85500-10-00
1983 P# 8U9-85510-10-00 without the hand warmer coil
1984-86 P# 80N-85510-10-00 with the hand warmer coil
1987-1991 P# 83H-85510-10-00Yamaha changed the charging coil in the stator to a higher output coil, by doing this the secondary coil output went up from 18,000 volts to 28,000 volts ,but you also have to use the 1987-91CDI as well as, it is different to accommodate the higher voltage of the charging coil in the stator.
F.Y.I. Double check P#'s !
http://cgi.ebay.com/ebaymotors/YAMAHA-N ... ccessories
http://cgi.ebay.com/ebaymotors/YAMAHA-V ... ccessories
http://cgi.ebay.com/snowmobile-vintage- ... 29f2f1b53c
http://cgi.ebay.com/Yamaha-snowmobile-l ... 29eb805525
http://cgi.ebay.com/ebaymotors/Lighting ... ccessories
http://wwww.alssnowmobile.com/PRODUCTPA ... deptid=624
Item #: AL198110 Condition: Remanufactured Price: $225.00
Year: N/A Make: Yamaha Model: VMAX 540 L/C
OEM: 80N-85510-10-00
Description: Remanufactured stator. There will be a $50.00 core charge added to the order before shipping. An RMA # is required to return your core for credit. May require sending your stator in for rebuild, depending on availability. Call for details.
Year: 1985-1986 Make: Yamaha Model: VMAX 540 L/C
* This Item is applicable to this Year/Make/Model
Item #: AL198402 Condition: Remanufactured Price: $225.00
Year: N/A Make: Yamaha Model: SRX 440 L/C
OEM: 8G9-85500-10-00
-CDI’s
1981 SRX 440 P#8K4-85540-10-00
1983-86 Vmax P#8U9-85540-10-00
1987-1991 Vmax P# 83H-85540-10-00
-Chrome cylinder Honing
Wiseco recommends finish honing the cylinders with any where from a 240 to 400 grit, and recommend 280 grit as best. We do have a soft hone available that will do the job nicely. The part # is W6077 and will work for 63-76mm bores. You can find more information on our website at http://www.wiseco.com
Tom Davis x3109
Technical Sales
tdavis@wiseco.com
Wiseco Pistons Inc.
7201 Industrial Park Blvd.
Mentor, Ohio 44060
(440) 951-6600
-Piston/ Rings 540
O.E.M. Piston 8U9-11631-01-94
O.E.M. Chrome bore rings 8U9-11601-00-00
Wiseco Chrome bore rings CDM
Wiseco sleeved bore Rings CD
-Piston/ Rings 1981 440O.E.M. Piston P# 8M6-11631-00-93
O.E.M. Ring P# 8M6-11631-00-00
Aftermarket Kimpex Piston stock bore P# 09-8023
-Carb. diagrams
http://www.sudco.com/mikuni2.html
Charles Schettler
734 Huefner Spring Road
Shippenville Pa. 16254
chkinetics@csonline.net
W 814 226-1595 M-F 7am-2pm
H 814 354-2687 Eve/Wknds.
* Please...... help Us Compile a list and post your Vin# in the Sticky or PM me ! *
_________________
-Thermostat
-Cold hand warmers
-Recoil Failures
-Lighting Coil
-Dimmer Switch
1987-VMX540-V-max
-T.S.S. Maintenance
-Off Season Storage
-CDI’s
Tom Davis x3109
Technical Sales
tdavis@wiseco.com
Wiseco Pistons Inc.
Mentor, Ohio 44060
(440) 951-6600
-Piston/ Rings 540
-Carb. diagrams
Charles Schettler
_________________
