Hey Guys, Well summer is over Whoo..Hooo..
Anyone have the proper procedure for adjusting the chain tension on an 83,
Thanks Steve
Chain Case Adjustment
According to my SRV Manuel, which looks to me to be the same
8-15 mm (0.32 - 0.59) freeplay Torque locking nut to3.5 m-kg (25 ft lbs)
Now personalby, because I change gears in some of my sleds at times which means the chains will have either much more, or much less slack, or at times a different length chain is needed. What I shoot for is that the chain is never to tight to bind on the gears or tennsionor, or to loose to ratchet. A 1/2 in of flex in the movement works fine for me
