fuel shut offs
fuel shut offs
both of my 81s do not have a fuel fuel shut off.i am running a 540 and i have read that the vmax does have a fuel shut off. is it a nice to have feature to shut the gas off when needed or did yamaha put these on for a reason,and wear abouts in the fuel system does it go,i am thinking before the pump.thanks for your input guys
The fuel shut-off's from the factory on the V-Max were on the left hand side on the dashpanel. My 87 still has the stock ones and they work. I took the assembly off my 86 as it was frozen and just installed in-line shut-off-s. In both cases my shut-off's are located after the fuel pump. It's always a good safety feature to avoid your engine flooding due to a gasket/diaphtam leak in the carbs. I use them when trailering or when the machine sits. It's also a nice feature when you want to run the gas out of the lines and the carbs when storing for the winter. This is just my opinion.
Hope this helps.
Hope this helps.
different years had different syles.... i believe it was the 83 and 84... maybe 85 that had the syle like above... the 86 had the remote cable kind... which dont seem as nice but whatever floats your boat... my 84 has two shut offs (2 pumps) and i can manage to turn them on while riding.... ya know like how i take off and realize once it starts sputtering that i forgot to turn the gas on.... quick lift the hood and turn them on... and never stop moving... been there done that...
Marc Machine
- Contact:
