				560cc Reed Vmax!!
				Posted: Wed Aug 09, 2017 6:53 pm
				by vmax-540
				Re: 560cc Reed Vmax!!
				Posted: Wed Aug 09, 2017 11:13 pm
				by killerklown
				Fun!
				Posted: Thu Aug 24, 2017 8:16 am
				Nice project Jeff, love to see something outside the box.
				Posted: Fri Jan 12, 2018 10:48 am
				Unreal, I am impressed, you certainly did not take the easier road and install a 94-96 Vmax 600 !
				Posted: Wed Apr 18, 2018 7:50 pm
				by vmax-540
				Have had a little time lately to work on this. I have a little more machine work to do and then I should be ready for a trial assembly. Here are a few more pictures. Added some ports to the intake, polished the exhaust port and increased the boost hole in the piston. Had to widen the head 25mm, and also had to extend the divider inside the head so the coolant wouldn't short circuit though the head and not down the cylinders and up & out the other side. I will keep you posted as I go.
				Posted: Tue Aug 21, 2018 8:36 am
				Any updates Jeff? Looking at mine, Perry and I were talking, IF we could spread out the bolts a little wider, we could go to a triple ex port. Might chase that a little further over winter
				Posted: Tue Aug 21, 2018 11:30 pm
				by vmax-540
				Still have a little work to do on it, but hope to have running in a couple of weeks. Haven't had a lot of time to work on it lately, buzy with other things. Will update when I get it finished and running.
				Posted: Mon Sep 17, 2018 1:49 pm
				by vmax-540
				Finished up the engine and installed it into the sled this weekend. Just need to get a throttle cable and widen the boost bottle. Looks like i will have to use K&N filters as there isn't room for the air box. Will find a new mounting place for the coil as well. Planing on firing it up  this coming weekend. Getting excited about getting it running. I will try and get an air box to work, but for now I will run filters.
				Posted: Mon Sep 24, 2018 12:41 pm
				by vmax-540
				Got in running this weekend. Started right up and no problems so far. Can't wait to get it on the snow. Check out the video.
https://youtu.be/dVK_j1gzgPM
				Posted: Mon Sep 24, 2018 8:10 pm
				Come on Jeff, find a grass drags out there somewhere, I waiting to hear how it does
				Posted: Wed Jan 09, 2019 9:31 pm
				by vmax-540
				Had the sled out last weekend for the first time. I haven't got the carbs or clutching straight yet but so far very pleased. It has a lot more bottom end then I thought and it just keeps on pulling. The jetting is close but still on the rich side, exhaust temps only about 1050 degrees. I know I can add at least 2 grams more weights in the clutch, I will work on it some more this week end.
				Posted: Tue Jan 22, 2019 12:43 pm
				Did you have to angle the engine more to get the carbs to clear?, I'm putting a 617 in my drag sled chassis and had to change everything up front to get the carbs to clear the tunnel and steering post. Got that close now, waiting for new rear skid to be finished, all wheels no slides.
				Posted: Tue Jan 22, 2019 12:50 pm
				BTW, made some small changes to my 83 V Max, had new domes made, now has 15.5/1 and I can't pull the rope when its cold LOL, little more port work. Never got it out again during grass season, hopefully going to NSSR race Feb 8th with it.
