Page 3 of 3
				Re: The Infamous 1983 Pump Drive Gear seal for the water pump !
				Posted: Fri Dec 20, 2013 6:10 pm
				by mcbang
				Are you sure the seal is 25x44x7? I measured one today and it was 25x42.
				Posted: Fri Dec 11, 2015 11:42 am
				Posted: Mon Dec 14, 2015 1:47 am
				by killerklown
				Pretty much unavailable everywhere.
				Posted: Sat Jan 09, 2016 12:25 pm
				by AdrenalineJunky
				mcbang wrote:Are you sure the seal is 25x44x7? I measured one today and it was 25x42.
25 44 11 is what mine has printed on it (83 model).  A couple 25 44 7 can be used with a few mm removed from both? I'd try it but don't need at this time. They are rated for 250* and 7 psi individually.
I see absolutely no need to get the newer housing if you use to right seal combo and install properly.  The 83 case will be just as good. I don't think it matters which way the seal spring faces either as both sides will get lubed from either coolant or oil. I think whats really important is to not overheat these on marginal snow or ice. The seals only hold about 7 psi so watch the temp and they should last a good long time.
http://www.usabearingsandbelts.com/18m7 ... 905:page=3
