Main jets!
Chris
Post by Chris »
Hey guys Sorry it took me so long , i still havent got the time to take a look at the needle , , , But i know i put 2 new needles in the v max in the summer the dumbie befor me bent one and i put 2 new ones in , I orderd them from a yamaha dealership and jus asked for stock needles for a V max 540 . i rememebers the numbers on the new ones were the same as the old one , , , But when i get time i gotta take a look at the slide cut away i found 2 old slides in the back compartment of the Sled the guy i baught this 540 from was real stupid , there were new slides in the sled so MAYBE he got the wrong number i will check tonight and report back tomorrow when i have the slides out i will check the needle numbers
Sorry for all the troubles
Chris
srxvmax50
carbs
Post by srxvmax50 »
Christo, needles stock: 6DH7?. Slide cutaways: 2.5.? I'm still not sure this is your problem., Maybe you got something else wrong, maybe? . What is your cyl. compression? The cyl. comp. is so important for fuel draw into the comb. chamber for the next charge and it shoulde be 120psi min. Oftentimes people findout afterward that their engine is sick inside. It's common with the old vmax, cause it's old.You might have to go back and take a re-look at your walls and pistons for scuff, and any bearing slop also. Hell, I dunno? Get back to me. MJD.
jetting
Heres what i have for jetting and its a pre delivery sheet that came wit my sled. its an 83 . id scan it but my scanner took a shit. so here it goes
main jets stock 330 change to 290
power jet Lh-135 stays 135
Rh130 change to 125
power air jet Lh 1.5 stays 1.5
Rh1.8? change to2.0
pilot jet Lh45 change to 35
Rh45 change to 35
air screw 1/2 turn for both.
and it says for all intents and purposes the final speciifications are now the standard specs for the v-max.use the final specs as your reference points when servicing or tuning your v-max.
also for the secondary clutch while im at it
the secondary spring preload is factory set at 40d(holes c&2)for use with the8u9 v- belt .an 8m6belt gives better overall performance during pre delivery remove the 8u9 belt .install an 8m6 and set the secodarary spring preload to60,70, 80 degrees wichever brings the shift rpm to 8100rpm
clutch spec
60 d- holes b-2
70 d--c-3
80d-a-3
shift rpm 8100+- 100 rpm
these are sea level specs
