My 1986 restoration and widening.
sxr1000
Post by sxr1000 »
Just a few pics of my 86 project so far,vmax 600 struts,this thing is WIDE!!!,notice the fuel pump relocaton,more pics to follow.
Nice work ! You may want to consider a softer set of T.S.S. springs for the 540. Even the softest springs (Yellow) for the heavier Vmax 5/600's are stiffer than any of the original springs. See the Articles section on T.S.S. spring rates.
sxr1000
Post by sxr1000 »
Hi, Chuck, I purchased a new vmax 600 in 94 and found that for our type of ditchbanging and open fields the springs were to soft and I went to a STIFFER set so I think the yellow will be OK, at least for now,
looking real good im just worried about that fuel pump... wouldnt that be even harder to get at than the stock location? whats that idea all about?
sxr1000
Post by sxr1000 »
I was having some bad fuel pump issues so I removed both of them and used one from a vmax 600,a very reliable pump,and it just cleaned things up a bit,one fuel line one impulse line one one oil line,it would be much harder to get at but like I said a very reliable pump,every thing feeds up from the bottom under the flatslide carbs and you dont see anything, I guess it is just a result of to much time on my hands,LOL.
