I am having a heck of a time trying to remove the skis off of my 86 v max. The bolts are set up and I can't remove them. Is it possible to cut the bolts and drill new holes?
Thanks for any help.
86 v max ski removal
Re: 86 v max ski removal
86maxjg, The collars are frozen to the bolts.... if you have tried penetrating fluid and heat then, grinding is probably the only solution.
Penetrating Oil Test
viewtopic.php?f=2&t=2350&p=8717&hilit=acetone#p8717
-T.S.S. Maintenance
On most every used T.S.S. sled I've bought the Knuckles and steel bushing are frozen and completely locked up and pivoting on the bolts ! I've bought sleds that the locked up joints won't even allow the springs to return let, alone the struts to work when hitting a bump. The T.S.S sleds have always gotten a bad rap for slop developing when the ungreased steel bushing's freeze up they grind away on the nylon washers ! I have sleds that are 15+ years old that have never had a bushing kit and are almost as tight as new. Just take the knuckles and the ski mounts apart every other year and grease !
http://www.ebay.com/itm/Suspension-Shim ... f3&vxp=mtr
http://www.ebay.com/itm/Yamaha-TSS-Fron ... 84&vxp=mtr
Shim Kits http://s15106.50belowcommerce.com/produ ... oducts=tss
http://www.mfgsupply.com/m/c/100-650.html
-T.S.S. Maintenance
